loop: sei
rcall Wstaw_Se_Odczyt_Z_Ulubionej_Klawiatury
ldi zl,low(Conversion*2)
ldi zh,high(Conversion*2)
add zl,r16
adc zh,zero
lpm r17,z
cpi r17,0x40
brlo standard_key
rcall Handle_Special_Key
rjmp loop_nc
standard_key:
ser r18
eor r17,r18
andi r17,0x3F
andi r16,0x80
or r16,r17
sts Char,r16
loop_nc: rjmp loop
Handle_Special_Key:
cpi r17,0x40 ; control
breq Handle_Special_Key_ctrl
cpi r17,0x41 ; shift
breq Handle_Special_Key_shift
cpi r17,0x42 ; start
breq Handle_Special_Key_start
cpi r17,0x43 ; select
breq Handle_Special_Key_select
cpi r17,0x44 ; option
breq Handle_Special_Key_option
cpi r17,0x45 ; reset
breq Handle_Special_Key_reset
ret
Handle_Special_key_ctrl:
andi r16,0x80
brne Handle_Special_key_ctrl_release
lds r17,Flags
ori r17,0x01 ; set control
sts Flags,r17
ret
Handle_Special_Key_ctrl_release:
lds r17,Flags
andi r17,0xFE ; clear control
sts Flags,r17
ret
Handle_Special_key_shift:
andi r16,0x80
brne Handle_Special_key_shift_release
lds r17,Flags
ori r17,0x02 ; set shift
sts Flags,r17
ret
Handle_Special_Key_shift_release:
lds r17,Flags
andi r17,0xFD ; clear shift
sts Flags,r17
ret
Handle_Special_key_start:
andi r16,0x80
brne Handle_Special_key_start_release
cbi PORTD,KEY_START
ret
Handle_Special_Key_start_release:
sbi PORTD,KEY_START
ret
Handle_Special_key_select:
andi r16,0x80
brne Handle_Special_key_select_release
cbi PORTD,KEY_SELECT
ret
Handle_Special_Key_select_release:
sbi PORTD,KEY_SELECT
ret
Handle_Special_key_option:
andi r16,0x80
brne Handle_Special_key_option_release
cbi PORTD,KEY_OPTION
ret
Handle_Special_Key_option_release:
sbi PORTD,KEY_OPTION
ret
Handle_Special_key_reset:
andi r16,0x80
brne Handle_Special_key_reset_release
cbi PORTB,KEY_RESET
mov r16,zero
sts InSync,r16
ret
Handle_Special_Key_reset_release:
sbi PORTB,KEY_RESET
ret
IRQ_pokey: push r16
in r16,SREG
push r16
push r17
push r18
sbi PORTB,POKEY_KR1
sbi PORTB,POKEY_KR2
lds r16,InSync
tst r16
breq IRQ_pokey_not_synced
lds r16,Counter
in r17,PIND
mov r18,r17
andi r17,(1<<POKEY_K0) ; PD2
andi r18,(1<<POKEY_K5) ; PD3
lsr r17
lsr r17
lsl r18
lsl r18
or r17,r18
andi r16,0x21 ; bit 5 & bit 0
cp r16,r17
brne IRQ_pokey_not_synced
lds r16,Counter
lds r17,Char
cp r16,r17
brne IRQ_pokey_cont1
cbi PORTB,POKEY_KR1
ser r18
IRQ_pokey_cont1:
cpi r16,0x2F ; shift line
brne IRQ_Pokey_cont2
lds r17,Flags
andi r17,0x02
breq IRQ_Pokey_cont2
cbi PORTB,POKEY_KR2
IRQ_pokey_cont2:
cpi r16,0x3F ; control line
brne IRQ_Pokey_cont3
lds r17,Flags
andi r17,0x01
breq IRQ_Pokey_cont3
cbi PORTB,POKEY_KR2
IRQ_pokey_cont3:
lds r16,Counter
inc r16
andi r16,0x3F ; max count value
sts Counter,r16
IRQ_pokey_exit:
pop r18
pop r17
pop r16
out SREG,r16
pop r16
reti
IRQ_pokey_not_synced:
cbi PORTB,ST_LED
IRQ_pokey_not_synced_l0:
in r16,PIND
andi r16,(1<<POKEY_K5)
breq IRQ_pokey_not_synced_l0
IRQ_pokey_not_synced_l1:
in r16,PIND
brne IRQ_pokey_not_synced_l1
mov r16,one
sts InSync,r16
clr r16
sts Counter,r16
sbi PORTB,ST_LED
rjmp IRQ_pokey_exit
Conversion:
; control - 0x40, shifts - 0x41, start - 0x42, select - 0x43, option - 0x44, reset - 0x45, cursor mode - 0x46
; 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
.db 0x80,0x1C,0x1F,0x1E,0x1A,0x18,0x1D,0x1B,0x33,0x35,0x30,0x32,0x0E,0x0F,0x34,0x2C ; 00
.db 0x2F,0x2E,0x2A,0x28,0x2D,0x2B,0x0B,0x0D,0x08,0x0A, 00, 00,0x0C,0x40,0x3F,0x3E ; 10
.db 0x3A,0x38,0x3D,0x39,0x01,0x05, 00,0x02, 00,0x22,0x41, 00,0x17,0x16,0x12,0x10 ; 20
.db 0x15,0x23,0x25,0x20,0x22,0x26,0x41, 00, 00,0x21,0x3C,0x11,0x42,0x43,0x44,0x45 ; 30
.db 0x80,0x80,0x80,0x80,0x46,0x80,0x80, 00,0x03,0x80,0x0E,0x13,0x80,0x14,0x06,0x80 ; 40
.db 0x04,0x80, 00, 00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80 ; 50
.db 00, 00,0x11, 00, 00,0x26,0x07,0x33,0x35,0x30,0x18,0x1D,0x1B,0x1F,0x1E,0x1A ; 60
.db 0x32,0x22,0x0C,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80 ; 70
; key released
