Czy ktoś widział w ogóle FGTIA na własne oczy?
"Jerry Jessop explains why French Ataris produce fewer colors:
I will tell you why it only has monochrome out, because it's SECAM and a
SECAM GTIA was never produced. The PAL GTIA is used in France and the Lum
outputs are run into an onboard encoder to produce a "pseudo" color depending
on the Luminance output, composite only. This is why a SECAM VCS or 800 has
nowhere near the same number of colors (16) availible as a PAL or NTSC unit
(256).
The FGTIA was never completed as the market size did not warrant the
expense. The largest SECAM market is not France but the Soviet Union
(former) and in 80-84 sales of these items there were not possible."
