Hello Tebe,
Can you please tell me what's wrong with code below, which results in this error:
.TEST
if_test.asm (11) ERROR: Bad parameter type
I use Mads 1.8.7 build 34 (28 Jun 09) and it raises an error if I try to use .and, .or combination in #if statement
Code:
org $3200
.var n1 .byte
.var n2 .byte
Main
mva #21 n1
mva #7 n2
#if .byte n1<#214 .or .byte n2=#7
#end
jmp *
run Main
2 Ostatnio edytowany przez tebe (2009-07-19 16:23:05)
it's bug in mads, '.OR', '.AND' not works
p.s.
mads 1.8.8 bug fixed
No problem, thanks for info.
