Greetings again,
i want ask, i anybody have schematic for SCART cable on XE/XL .. i need build it
many thanks
ATARI 800XE with u1mb, stereo, covox, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers
my youtube channel
2 Ostatnio edytowany przez Monsoft (2009-05-17 20:49:08)
This should be enough http://www.dereatari.republika.pl/images/scart.gif
done :) thank you
my youtube channel
interesting.. when i plug SCART and sio2pc, TV making amazing zzzzzzzzz
my youtube channel
"ground loop" ;)
wszystkie trzy strony świata
how i fix it?
my youtube channel
At first your PC, TV, and Atari must be plugged into the same power outlet. If you have an cable TV connected to the TV, disconnect the cable from antenna socket (in TV) or put the galvanic separator between TV and Cable TV network.
8 Ostatnio edytowany przez w1k (2009-05-19 09:53:44)
i try it tomorow
now, it is fine, thank you :)
my youtube channel
