Plopbox!
a java applet which plays ahx,ym,fc,mod,xm,s3m and soon sid&ay
\o/
looking nice but for me it's take little too much CPU time :(
Should be at Emu-16bit. Moving.
4 Ostatnio edytowany przez grzeniu (2006-10-31 18:45:44)
monsoft: upgrade your machine. Max 6% of CPU utilization (due to Java VM) in a peak at 1.5GHz (AMD) should be enough.
Btw. Co porabiasz w Chameryce ?
PIN ready logo
5 Ostatnio edytowany przez Monsoft (2006-11-01 07:35:23)
I have a AMD 900 and Windows 2000 (for me, who doesn't play games on it that's enough - for games I have a Xbox 360) and usually the Task Manager showing me %57 of CPU use. So it's lot of power for me poor CPU. I will check how is under Ubuntu which is my secound system on it.
And is no support for SAP files (player support SID files) :(
Ja u Wuja Sama pracuje, wydaje zarobione pieniadze i mieszkam od jakis 3 lat (z przerwami na pobyty w UK gdzie za to u Krolowej robie to samo od jakiegos ponad roku).
6 Ostatnio edytowany przez pirx (2006-11-04 22:22:52)
Monsoft napisał/a:
I have a AMD 900 and Windows 2000 [----] the Task Manager showing me %57 of CPU use.
There must be something wrong with your Java Virtual Machine - I have a worse setup (700Mhz) in my laptop and the load rarely exceeds 25%.
The above statement is false! I have similar results to Monsoft.
http://www.5oft.pl/
I have ppc system and java for linux is definitely slower that osx version. Maybe it depends of JVM version ?
it must depend on jvm version.
1.4.2 is realy slow in comparison with 1.5.0
beta versions 1.6.0 are fare more faster also...
9 Ostatnio edytowany przez Monsoft (2006-11-03 06:49:54)
pirx napisał/a:
I have this same situation on two machines (one AMD 900, secound P III 800). Both Windows 2000 Prof and more than 512MB Ram. A have installed Java Runtime Version 1.5.0 (build 1.5.0_09-b03).
No fakt ze konfig masz nieco gorszy niz ja. Robiles jakies dodatkowe configuracje Jav'y u siebie ???
Zaraz sie przeloguje na Ubuntu i zaobacze jak tam.
No Ubuntu nie jest lepiej:
      PID USER      PR  NI  VIRT  RES   SHR  S %CPU %MEM    TIME+  COMMAND
  5185   irekp     16   0  271m  57m  13m S 45.6  3.2        4:13.13 java_vm
Czyli nie wiem jak tobie udalo sie uzyskac 25% zajetosci procka przy gorszym konfigu
10 Ostatnio edytowany przez pirx (2006-11-04 22:21:27)
Monsoft napisał/a:
Może PIII i dużo memorii to robi? Javka jakaś najnowsza co się automatycznie ściągnęła... A może mam więcej Mhz tylko o tym nie wiem (:
Żeby nie dopisywać nowych postów - mogłem się pomylić i patrzeć na nie te statystyki bo miałem otwartą operę, FF, eMulca i IE na raz (:
Sprawdzę jeszcze w domu ale chyba cuda się nie zdarzają.
Odszczekuję == hau hau!
Mam podobne wyniki, musialem patrzeć nie na te cyferki, co trzeba!!!
http://www.5oft.pl/
11 Ostatnio edytowany przez Monsoft (2006-11-03 08:46:36)
No ten PIII 800 co mam w robocie to ma 1.5 GB Ramu wiec sie zbytnio nie zatyka, a jesli nawet to tylko pod winda, pod linuxem chodzi bez zarzutu. Moglbym winic winde, ale podobna zajentosc czasu procka jest pod linuxem.
Tak wiec moze ty masz 1700 MHz a nie 700MHz ??? ;)
Ale tak odchodzac od tego ile co zajmuje czasu, to ten playerek nawet fajnie gra :-)
