1 Ostatnio edytowany przez carmel_andrews (2006-05-03 11:46:45)
I was referred to this w/s (forum) by 'fox', also a member of AA (atariage)
Firstly, i am sorry i don't speak polish (please excuse my ignorance)
Perhaps you Atari hackers/fans can help me though
I recently downloaded a batch of ebooks and etext's from a polish atari 8bit w/s called 'tajemnice' (whatever that means)
I got the following (copying over the filenames)
Asembler_6502_oryginalna.zip
Asembler_6502_poprawiona.zip
Podstawowe_procedury_systemu_operacyjnego.zip
Procedury_interpretera_basica.zip
Procedury_wejscia_wyjscia.zip
qa_pdf.zip
their were others as well on tajemnice's w/s
I was hoping that there is some one out there with english versions of these ebooks/text or can translate them for me
Alternatively, preferably an Atari equivalent to a massive c64 ML tutorial i recently downloaded (about 11meg's worth)
'Tajemnice Atari' means 'The Secrets of Atari'.
What about using google? There are a lot of ML tutorial for 8-bit Atari in the web, i.e. there are some books at http://www.atariarchives.org
Already tried that epi...doesn't seem to be anything apart from Spalg which is no longer available, that's why i d/l the bumpf from tajemnice's w/s
Fox said that a couple of the books (on tajemnice's w/s) helped him in learing assembler on the A8
I doubt you'll find these books english versions, but some of it (or all)
was antyway based on english sources, so just look for 'bibliografia' :) in it.
You can find some info about 8 bit Atari in Mapping the Atari by Ian Chadwick.
Lot of info, appendix etc.. In case you want offline version and you don't want (lazy, lazy)
to do it yourself then mail me :). That's about Atari itself and Atari specific stuff.
About 6502 programming - i think you can find lot of these :) (net).
---==<<Sc0rpi0>>==---
"Asembler 6502" by Ruszczyc was the only good book for beginners that I could recommend, until recently I found this:
http://www.westerndesigncenter.com/wdc/ … manual.pdf
