Hmm,
downloaded this game. Looks good, but how to start the main program ?!?
- With Spacebar one can choose the background area, but how do I start the game ???
I tried Return, Start and Joystick Trigger/Button but they all did not work; the ESC-key gave only a blank screen...  so what key starts the game ???    -Andreas Magenheimer.
There is something wrong with Your ATR image I think. After ESC button the game should start. I can send you working ATR if You want, just post your private e-mail.
Well,
my e-mail adress is:   amp@abbuc.de
Maybe the program does not like my 512k RAM enhancement (Compyshop and TOMS compatible!), meaning my Atari 800XL has 576kbytes RAM now... a few other programs (for example Jungle Hunt cart.) display garbage when in the 576k mode (I switch back to old Atari 400/800 OS and in most cases the problem is solved then, not so with Brutal Karate)...    greetings, Andreas Magenheimer.
Check out Your e-mail box.
