Hi!
Lamer Fandal has a problem! :)
I have a CMC song and I need it to play in my code. What I must do? Is there any way how to export CMC song as a binary executable module? Or where I can find some suitable player code with documentation?
Thank you very much for any help,
F.
Problem is solved. Sorry for stupid question.
You can delete your question using button "zmień" on the right side your post subject. Next, mark option "Usuń ten post" and push button "Wyślij". You know, sometimes you puting some question and after short while you are able to answer yourself. We are only people ;)
