no fakt; na sieci mało o Tomsie: w zasadzie to ogólnikowe informacje:
http://www.serious-dial.atari.pl/SSerious/S01/A09.html
http://www.faqs.org/faqs/atari-8-bit/fa … on-21.html
http://www2.asw.cz/~kubecj/asiop.htm
Jako że 710 i 720 są podobne to:
# TOMS 720 -double head disk drive, with mounted interface Centronics, chips: CPU 8085, WD2797, PIA 8255 (for handle Centronics), 32 KB ROM, 8 KB RAM
ROM contains: OS of drive, MYDOS 4.50 and some utilities (copy, format, etc)
ROM is seen by computer as drive D1: (if drive is open), and D3: (when drive has number D1:) or D4: (when drive has number D2:). It makes possible load DOS from ROMdisk during booting system.
Formats of disks:
* SS/SD - 40 tracks, 18 sects, 128 bytes = 90 KB
* SS/ED - 40 tracks, 26 sects, 128 bytes = 130 KB
* SS/ED - 40 tracks, 18 sects, 256 bytes = 180 KB
* SS/ID - IBM S-9 - 40 tracks, 9 sects, 512 bytes = 180 KB
* DS/DD - 40 tracks, 18 sects, 256 bytes = 360 KB
* DS/QD - 80 tracks, 18 sects, 256 bytes = 720 KB
* DS/ID - IBM D-9 - 40 tracks, 9 sects, 512 bytes = 360 KB
Transmition modes:
* normal - 19200 bps
* Turbo - 70000 bps
* Ultra Speed - 70000 bps
Also tracks buffering.
# AS SN-360 -double head disk drive, 5.25", CPU 8051, controler WD2797, 19200 bps
Available formats:
* SS/SD - (FM) single sided, single density - 90 KB
* SS/ED - (MFM) single sided, enhanced density - 130 KB
* SS/DD - (MFM) single sided, double density - 180 KB
* DS/DD - (MFM) double sided, double density - 360 KB
# TOMS 710 (The newest polish disk drive and probably the best one).
Similar to TOMS 720, one more format:
* double sided, 80 tracks, IBM (720 KB)
Transmition modes:
* standard 19200 bps
* TOMS Turbo (loaded from ROMdisk if drive is open) - 67000 bps
* Ultra Speed (QMEG-OS, SpartaDOS) - 67000 bps
ROMdisk contain:
* MYDOS 4.50
* COPY
* INIT
* TURBO - turn on/off TOMS Turbo mode
* BASIC - turn on/off Atari Basic
* AUTORUN.SYS - ramdisk
* README
Also TOMS Navigator instead of DUP.SYS. It is program similar to NortonCommander on PCs. IBM-ST copier on additional disk.
ZTCP to Piguła miał kiedys chyba 720-tke a Vidol prawie jestem pewien że posiadał właśnie 710-tke;więc uśmiechnij sie Stryket właśnie do nich :rolleyes:
gep/lamers^dial
