326 Ostatnio edytowany przez mono (2023-11-15 21:37:51)
Drum Machine is a tool to play specified samples once you press a key (HELP, START, SELECT, OPTION, BREAK and SHIFT), push joystick in specific direction or press a trigger. This is a tool I made for Pinokio. He used to use it on his chiptune concertos. Sample playing speed is very arbitrary because by design it was used to play only drum samples, not for the music nor playing tones.
Edit: Try /A $D600 /O COVOX
327
uhm, understand.. so on atari doesnt exist SDX covox player?
ATARI 800XE with u1mb, stereo, covox, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers
my youtube channel
328
hmm, probadly i found a bug? dont know if is about sdx, or its about sparta commander
https://www.youtube.com/watch?v=EYSI6PtC5zo
When i trying view CAR directory, system crash.
latest beta SDX, u1mb, latest altirra firmware (4.20-test30)
my youtube channel
329
w1k napisał/a:
Confirmed. The real bug in the CAR: driver, but SC should not crash either.
It will get fixed for a next release. Thanks for the report.
330
dir MEDIA not sorted? i tried all methods (name, type, size, date)
sc1.png 147.4 kb, nikt jeszcze nie pobierał tego pliku.
sc2.png 143.9 kb, nikt jeszcze nie pobierał tego pliku.
my youtube channel
331
It looks like sorted. By name.
332
I think that he means that the left panel is not sorted.
The sorting routine checks first if the directory is already physically sorted (by the same algorithm). There was a bug in it and that check sometimes returned false positives, which resulted, obviously, in a directory not being sorted.
That bug has been already fixed, I believe, almost 2 years ago. Any SDX version later than that should sort stuff properly (the sorting module is on the CAR device, not inside the Sparta Commander).
So the resolution is: update SDX to a revision later than January 2022, then report back, if the problem persists.
333
yes, i now flash sparta dos to 4.49g and same results (i tried sorting, still same)
sc1.png 38.53 kb, nikt jeszcze nie pobierał tego pliku.
sc2.png 112.37 kb, nikt jeszcze nie pobierał tego pliku.
my youtube channel
334 Ostatnio edytowany przez drac030 (2023-12-05 14:08:48)
w1k napisał/a:
Hmm, it seems that even 4.49g is earlier than that fix (9 January vs 16 January).
Try this: use the SDX Imager and replace the sortdir.ovl file in 4.49g with the one attached here. Then flash the resulting ROM image and see if it helped.
sortdir.ovl 1.52 kb, liczba pobrań: 2 (od 2023-12-05)
335
uh, i create new directory and directory MEDIA sorted correctly.. strange (without new sortdir.ovl), so i dont know if i must flash it now
my youtube channel
336
w1k napisał/a:
Yup, that bug is not easy to trigger :)
337
exist solution how speedup sparta commander? reloading disks is very slow, now i have side 3, im using fat16 partition, but looks same like loading from apt
my youtube channel
338 Ostatnio edytowany przez drac030 (2023-12-28 00:30:11)
w1k napisał/a:
What do you mean exactly by "very slow"? Some reference below:
https://youtu.be/l7eot0MXoKQ (VBXE)
https://youtu.be/hbvAbkDCYdQ (no VBXE)
339
i think with vbxe is faster, so that the solution for me.. vbxe:)
my youtube channel
340
hello, any news of new version?
my youtube channel
341
Unofficially, yes ;)
342
show ;)
my youtube channel
343
any chance for new version?:)
my youtube channel
344
http://atariki.krap.pl/index.php/Napisz_se
345
Tebe, że zadam takie pytanie: mało Ci było, kiedy Cię Solo sponiewierał na AAge parę dni temu? Szukasz po tym nowej zaczepki czy co? Bo nie rozumiem.
346
sponiewierał czytaniem bez zrozumienia ?
347 Ostatnio edytowany przez w1k (2024-09-24 17:05:33)
Pri prezerani suborov niekedy sparta commander zamrzne.
sc.jpg 502.52 kb, nikt jeszcze nie pobierał tego pliku.
my youtube channel
348
Co takiego? ;-)
349
mrzne pri prezerani adresarov..
my youtube channel
