Cześć chłopaki ;)
As I'm co-organizing this year's Forever edition, this post serves as a reminder for two things:
- there's a lot of people coming, feel free to join our Atari forces: http://forever.zeroteam.sk/visitors.php
- there's a lot (and I mean a LOT) of good / valuable prizes for each Atari compo - mostly "thanks" to Covid and the cancelled years, we literally have two boxes of prizes to give away so feel free to participate in any compo, there's literally 100% chance you'll get something. ;) (see http://forever.zeroteam.sk/info.php for rules)
Any questions, feel free to ask or write to to our atari email.
pozwolę sobie jednak i tu zapytać, bo są pewne sprawy wymagające precyzyjnej informacji:
reg forever napisał/a:
- Atari 13oXE, 2o48+64kB RAM, Stereo, Atari XF 551 (SD, MD, DD, DS/DD - 32o KB/disk
z czym jest zgodne to rozszerzenie RAM i co to za format 320KB/disk
-  the allowed formats: self running or MPT (without samples), CMC, TMC (4 or 8 channels) - we will use MegaPlayer 2.o for exhibit
Rozumiem, że praca może być w pliku wykonywalnym i nie musi być to jeden ze wspomnianych formatów, ale:
- MD DOS (memlo:$1859).
... czy ten plik musi uruchomić się spod tego dosa, czy można dostarczyć jakiś BOOT DISC by tego uniknąć.
- there is forbidden to redraw others works. all the graphics must be performated on atari. no scans, converting from other platforms!
... czyli grafika musi być wykonana na Atari? ... czy to źle zrozumiałem? :) czyli nie dopuszczacie prac z G2F?
Oh man, I see that I have to update the rules as well. Those were written by -XI- to fit his machine; I'm pretty sure we don't have MD DOS anymore. :)
As for the hardware, we should have there a 600XL with U1MB, SIDE2, stereo etc, so pretty standard stuff.
I see that the note about (not) using G2F for example is a bit strongly worded as well. ;)
TL; DR version is: standard stuff, make sure it runs on real hardware. If in doubt, drop me a message to atari@zeroteam.sk and we'll check it out on our Atari.
Następna sprawa. Brak informacji o cenie wejściówki, oraz nie widzę adresu. Jest tylko wzmianka, ze to "culture house". Czyli co, gdzie?
5 Ostatnio edytowany przez sebaloz (2023-03-14 18:56:31)
Pin napisał/a:
Wejsciowka 20 euro. Po adres kliknij na "cultural house" - przekieruje do google maps.
Suchá nad Parnou 68, 919 01 Suchá nad Parnou, Słowacja
6 Ostatnio edytowany przez Pin (2023-03-14 21:59:47)
sebaloz napisał/a:
"culture house" jest u mnie nie klikalny :)
ok, informacje kompletne. Choć szkoda że najważniejsze nie są widoczne na pierwszy rzut, tylko między wierszami szukać tego gdzieś trzeba.
If it makes you feel better Pin, for the very same reason I put the map link directly in our atari.sk announcement: http://atari.sk/forever-2023-robot-uz-tento-tyzden/ ;-)
Poprawiło ;) ok, startujemy w piątek około 9:30, trasa na 6-7 godzin według map Google. Skład: epi, kris3d, hellboi, Argasek, pin. Będzie wesoło :)))
dalekoooooo.....
Pin napisał/a:
Mnie podaje także 7h  a kurca jeszcze dalej   https://tiny.pl/w8w9l
Miłej zabawy partyzanty
8,5h
stream: https://www.twitch.tv/forever_demoparty
https://www.lexaloffle.com/bbs/?tid=52076
tu moja prodka z Wilda - miłej zabawy :)
Solo - ale pod linkiem, który wysłałeś jest info, że nie ma tam żadnych treści..
Ten stream to w ogóle działał? Co kliknęłam, to brak treści.
oto koło :r przyp "pole 3,142857 * :r * :r przyp "l 2 * 3,142857 * :r przyp "i l / 360 powtórz 360 [np :i lw 1] już
Mi się udało wbić, ale jakość była tak fatalna, że prawie nic nie było widać. Jakaś kiepska kamerka ustawiona na bigscreen.
a jakieś zdjęcia są?
tu jest podsumowanko:
https://www.youtube.com/watch?v=LiEsYMRFOaE
i jakieś zdjęcia od krupkaja:
http://www.krupkaj.cz/xgal/album.php?show=Forever2023
