The #FujiNet NOS for #Atari8bit is progressing nicely, thanks to the hard work of Michael Sternberg (@16kRAM). https://youtu.be/hp0fjKt2w3g
Version 0.3.0 adds:
* an on-line help system (which pulls its pages from GitHub!)
* simple batch processing (using the SOURCE command)
* TYPE command to view files
Still to be done, is a COPY command.
But even at this stage, I am sure you will agree, that this DOS Replacement shows significant flexibility and usefulness.
Do you want to hack on it?
The code is here: https://github.com/FujiNetWIFI/fujinet-nhandler in the nos/ folder.
