Nie wiem, czy już było.
Było już...?
https://www.cbmstuff.com/index.php?rout … duct_id=60
______________________
The WiModem232 is an internet modem for any computer with a RS-232 interface port that emulates a standard Hayes compatible modem. Just plug the WiModem232 into the "serial" port and connect to BBS's all over the world or run a BBS of your own!
The WiModem232 requires access to your local router and supports easy WiFi setup, including WPS one-button setup!
Firmware updates are done using a simple command that fetches the latest firmware from the CBMSTUFF.COM server and updates the WiModem232 - all without ever having to remove the WiModem232 from your computer!
The WiModem232 hardware supports 300 baud to 115200 baud. Note: the terminal software you are using determines the maximum baud rate.
The WiModem232 requires external 5v power. Connect any 5v source (PC, phone charger, etc.) using a cable having a Mini-B type USB connector.
The WiModem232 V2 controls ALL of the standard RS-232 lines: Rx/Tx, RTS/CTS, DTR/DSR, and DCD all at the same time. This means that you can use the WiModem232 to run a BBS!
A DB25 to DB9 or RS-232 gender changer may be required for your particular computer. These are available separately. The WiModem232 uses a DB25 female connector (plugging into a DB25 male port).
______________________________
Works with the following computers:
Atari ST (all models)
Commodore Amiga (all models, A1000 requires gender changer)
IBM PC (all models wtih DB9 or DB25 - may require converter or gender changer)
Apple 8 bit (all models, requires proper cable)
Geneve
Tandy 100/102
Atari 400, 800, 800XL
Colleco Adam
TI99-4/A
BBC Micro
RS-232 dumb terminals
...and many others!
Ha. Ciekawe.
