Witam wszystkich.
Zacznę może od filmiku z problemem:
https://www.youtube.com/watch?v=Ha5NFQN9Gp8
Jak słychać, dźwięk nie jest czysty - jest "poszarpany" - i tu jest problem, jednak to nie problem Altirry.
EDIT: Generalnie dźwię działa prawidłowo w aplikacjach natywnych.
Obstawiam kłopoty z obsługą grafiki (Intel i915)
Konfiguracja Linuxa:
System:
Host: <filter> Kernel: 5.10.0-10-amd64 x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-10-amd64
root=UUID=<filter> ro quiet splash
Desktop: KDE Plasma 5.20.5 wm: kwin_x11 dm: SDDM
Distro: MX-21_KDE_x64 Wildflower October 20 2021
base: Debian GNU/Linux 11 (bullseye)
Machine:
Type: Laptop System: LENOVO product: HuronRiver Platform
v: Lenovo B570e serial: <filter> Chassis: type: 10 v: 0.1
serial: <filter>
Mobo: LENOVO model: Emerald Lake v: FAB1 serial: <filter> UEFI: LENOVO
v: 44CN43WW date: 10/27/2011
CPU:
Topology: Dual Core model: Intel Pentium B950 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7
microcode: 2F L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 8380
Speed: 1104 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 1104
2: 1509
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: mds mitigation: Clear CPU buffers; SMT disabled
Type: meltdown mitigation: PTI
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel 2nd Generation Core Processor Family Integrated
Graphics
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0106
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa compositor: kwin_x11 resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Audio:
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Sound Server: ALSA v: k5.10.0-10-amd64
Network:
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Lenovo driver: ath9k v: kernel port: efa0 bus ID: 02:00.0
chip ID: 168c:002b
IF: wlan0 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: eth0 state: down mac: <filter>
Drives:
Local Storage: total: 521.66 GiB used: 85.30 GiB (16.4%)
ID-1: /dev/sda vendor: A-Data model: SU630 size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 229a scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD3200BPVT-24JJ5T0
size: 298.09 GiB block size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01
scheme: GPT
Info:
Processes: 222 Uptime: 17h 09m Memory: 7.69 GiB used: 2.69 GiB (35.1%)
Init: SysVinit v: 2.96 runlevel: 5 default: 5 Compilers: gcc: 10.2.1
alt: 10 Shell: quick-system-in running in: quick-system-in
inxi: 3.0.36
Jeśli za szczegółowo, to przepraszam :P
Wine jest z mojej dystrybucji i ma wersję 6.22 (taką pokazuje)
Próbowałem różnych ustawień samego Wine, jednak żadnych efektów.
OpenGL nie działa mi w Wine - pokazuje mi śmieci, albo czarny ekran :/
Macie może jakiś pomysł, gdzie szukać rozwiązania? (Zmiana sprzętu nie wchodzi w rachubę ;) )
--- EDIT
Zmieniłem jeszcze sterownik grafiki na Intelowski, poprzedni to 'modesetting' (?)
Graphics:
Graphics
chip ID: 8086:0106
Display: x11 server: X.Org 1.20.13 driver: intel compositor: kwin_x11
Moje odczucia są mieszane. Altirra jakby mniej szarpała, jednak na rendererze wine ustawionym na OpenGL robi dziwne klony okna emulacji (?)
I raczej złym efektem ubocznym, jest migający ekran interfejsu KDE :/
Więc wracam do poprzednich ustawień :(
