76
Test pokazuje, że formatowanie kończy się powodzeniem na Sio2SD. Ale nie kończy się dla Atari, przynajmniej aż do end Timeoutu. Czyli zapomniano wysłać STATUS ok.
77
hm, i try re-flash with atmel cable, but i wait for USB-LPT..
ATARI 800XE - u1mb, pokeymax4, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, a8 pico sio, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers. ATARI 800XE - 2xos (XL OS, Q-MEG), ATARI 800XE stock
my youtube channel
78
i using this cable from flash sio2sd
http://www.atari.turiecfoto.sk/albums/a … G_0598.jpg
i have new MB on pc without LPT..
can i use this cable?
http://www.softcom.sk/eshop/delock-konv … 05272.html
my youtube channel
79
I don't think so...
Bu I can recommend yu to buy a cheap chinese USBASP version.
Fx:
http://www.ebay.co.uk/itm/New-USB-51-AV … 3ccb7ad641
jmp $e477
80 Ostatnio edytowany przez lemiel (2013-03-18 13:59:12)
This LPT-USB converter probably will not work correctly.
There are special LPT-USB converters for programming devices, and they are not cheap.
This USBASP could help you. But seller is not sending to Slovakia - see exclusions list, probably post offices not collaborates.
Try to find it locally.  Or another seller. And wait for delivery, 3-4 weeks.
Better, if you have more cash: http://www.ebay.co.uk/sch/i.html?_nkw=g … programmer
81
i buy LPT for PC.. - 7EUROS
my youtube channel
82
not working..
video:
https://www.youtube.com/watch?v=GjQHXXRH8oY
windows 8 64bit
my youtube channel
83
Let me guess.
Does this CARD support parralel port at STANDARD adresses ?
jmp $e477
84
where i can find that?
more info:
http://www.alza.sk/axago-pcia-p1-d283795.htm
my youtube channel
85
Podpora Re-Map IO Address – nastavení adresy LPT portu (tato funkce je podporována pouze v DOS)
Chceck drivers settings.
jmp $e477
86 Ostatnio edytowany przez w1k (2013-03-22 12:44:09)
I/o Dc00-dc07
I/o D880-d887
my youtube channel
87
http://en.wikipedia.org/wiki/Parallel_port#Interfaces
Most PC-compatible systems in the 1980s and 1990s had one to three ports, with communication interfaces defined like this:
LPT1: I/O port 0x3BC, IRQ 7 (usually in monochrome graphics adapters)
LPT2: I/O port 0x378, IRQ 7 (dedicated IO cards or using a controller built into the mainboard)
LPT3: I/O port 0x278, IRQ 5 (dedicated IO cards or using a controller built into the mainboard)
If no printer port is present at 0x3BC, the second port in the row (0x378) becomes LPT1 and 0x278 becomes LPT2. Sometimes, printer ports are jumpered to share an interrupt despite having their own IO addresses (i.e. only one can be used interrupt-driven at a time). In some cases, the BIOS supports a fourth printer port as well, but the base address for it differs significantly between vendors. Since a fourth printer port is conflictive with other features on PS/2 machines, it typically requires special drivers in most environments.
jmp $e477
88
so.. can i change it or..? move card to trash?:)
my youtube channel
89 Ostatnio edytowany przez willy (2013-03-22 13:07:16)
Or better use another programmer sw.
Try avrdude.
AFAIR it allows you to give a specific IO adress instead of LPT1.
-- edit:
Its explained fx. here:
http://arduino.cc/forum/index.php?topic=48737.0
jmp $e477
90
i cant setup it.. :/
milion of options..
my youtube channel
91
What about gui for avrdude ?
http://sourceforge.net/projects/avrdude-gui/
jmp $e477
92 Ostatnio edytowany przez w1k (2013-03-22 13:32:13)
execution of command loaddrv status failed
f**k of that..
i go try install windows xp..
or windows 3.1 maybe better..
vrrrrr
my youtube channel
93
Before using AVRDUDE, the giveio.sys driver must be loaded. The accompanying
command-line program, loaddrv.exe, can do just that.
Google is your friend.
http://nongnu.uib.no//avrdude/avrdude-doc-5.4.pdf page 24
jmp $e477
94
maybe in next life.. im trying flash it 5-6 hours? i bored reading 500 manual papers, with my poor english..
i go try win xp 32bit..
but thanks for replies :)
my youtube channel
95
windows 7..
LOL
now when cable is in sio2sd, sio2sd boots normal.. no activity
my youtube channel
96
today received USBasp
my youtube channel
97
bude nove RC?
my youtube channel
98
Fakt, jest parę niedociągnięć. Ale Acid nie odpowiada na e-maile od roku... tylko on ma źródła. Mogę w smutku pogrążony napisać - że pewnie projekt umarł... albo sam napiszę wszytko od nowa na większy procek.
Błędy:
- ATR nie pełnej wielkości (ostatni sektor różny od 128/256b) = zwis wsadu
- Nie kończy formatowania ATRów = czeka aż do Timeout
Niedociągnięcia:
- dostęp do FAT tylko dla jednego pliku jednocześnie (nie mylić z D1-D15 i V0-V99) - rozkazy: Cmd>$20
99
Zawsze pozostaje jeszcze Reverse Engineering - ale prościej byłoby gdyby autor uwolnił źródła.
jmp $e477
100
A większy procek się zmieści w te same płytki?
