To jest z opisu ROUTE.TAB:
# This is the routing table, to be used by the router to route IP datagrams
# Format of routes comprises four entries, separated by TABs :
# - First the network (subnet number) which can be reached by using this
# route.
# - Next the subnet mask associated with that network.
# - Then the port name follows. This is the name as listed by ConfSTinG or
# STNGPORT.CPX.
# - Last entry is the IP address of a host on the attached network that
# can act as a gateway.
# The network specified can be directly attached to the specified port, in
# that case no gateway is needed, as the datagram can be routed directly.
# For a route to a network that is directly attached therefore the gateway
# entry should be set to 0.0.0.0.
# For an attached Ethernet the gateway entry specifies the gateway out of
# the Ethernet, for a serial line it is simply the host at the other end.
# It is advisable to finish the table by a default route. This route is most
# easily obtained by specifying a network 0.0.0.0 with a netmask 0.0.0.0.
# Routes with invalid addresses or absent ports are ignored.
# 192.68.0.0 255.255.255.240 Modem 1 192.68.0.1
# 130.75.75.0 255.255.255.128 Ser.2/LAN 0.0.0.0
# 0.0.0.0 0.0.0.0 Ser.2/LAN 130.75.75.16
Czyli tak jak jest napisane a takze tak jak napisal Artik-wroc, linia routingu powinna byc taka:
0.0.0.0[Tab]0.0.0.0[Tab]EtherNet[Tab]Default_gateway_IP
Czyli:
0.0.0.0/0.0.0.0 <- to mowi ze chodzi o kazdy ruch wychodzacy
EtherNet <- Nazwa twojego urzedzneia sieciowego
Default_gateway_IP <- Adres IP gateweya gdzie caly domyslny ruch wychodzacy bedzie pchany
Mozna jeszcze dodac na poczatku linie odnosnie transmisji do sieci wewnetrzej (directly connected to network interface), np:
192.168.1.0 255.255.255.0 Ethernet 0.0.0.0
Zakladam iz twoja siec wewnetrzna ma adres 192.168.1.0/24
