To jednak konwersja się nie udała a pliki są w całości (wielkość stok. pliku zapisana jest w 2. i 3. bajcie).
Poniżej listing konwertera (może się przydać również do analizy pliku stokenizowanego).
1000 REM MAC/65 TOKEN CONVERTER
1010 REM (C) 1987 ANALOG COMPUTING
1020 REM WRITTEN BY CHARLES BACHAND
1030 REM
1040 DIM TS(255),TE(255),HEX(15)
1050 DIM A$(40),TOKEN$(500)
1060 GOSUB 1470:GOSUB 1660
1070 TRAP 1070:? :? "RETURN for directory or name of":? " MAC/65 file";
1080 INPUT A$:IF A$="" THEN GOSUB 1740:GOTO 1070
1090 OPEN #1,4,0,A$
1100 GET #1,A:GET #1,B
1110 IF A=254 AND A=B THEN 1130
1120 ? "$)Not a MAC/65 File!":GOTO 1070
1130 GET #1,A:GET #1,B
1140 ? :? "File length = ";A+B*256+4
1150 TRAP 1150:? :? "RETURN for directory or name of":? " OUTPUT file";
1160 INPUT A$:IF A$="" THEN GOSUB 1740:GOTO 1150
1170 OPEN #2,8,0,A$
1180 REM
1190 REM PROCESS A LINE
1200 REM
1210 TRAP 1440
1220 GET #1,A:GET #1,B:GET #1,L
1230 L=L-3:PRINT #2;A+B*256;" ";
1240 GET #1,A:L=L-1:IF A<>88 THEN 1270
1250 FOR B=1 TO L:GET #1,A:PUT #2,A
1260 NEXT B:PRINT #2:GOTO 1220
1270 IF A<128 THEN 1320
1280 FOR I=129 TO A:GET #1,A
1290 PUT #2,A:L=L-1:NEXT I
1300 IF L=0 THEN ? #2:GOTO 1220
1310 GET #1,A:L=L-1
1320 ? #2;" ";TOKEN$(TS(A),TE(A));" ";
1330 IF A=0 THEN 1250
1340 IF L=0 THEN ? #2:GOTO 1220
1350 GET #1,A:L=L-1
1360 IF A>128 THEN C=A:FOR B=129 TO C:GET #1,A:PUT #2,A:L=L-1:NEXT B:GOTO 1340
1370 IF A=7 THEN GET #1,A:GET #1,B:? #2;A+B*256;:L=L-2:GOTO 1340
1380 IF A=8 THEN GET #1,A:? #2;A;:L=L-1:GOTO 1340
1390 ? #2;TOKEN$(TS(A+128),TE(A+128));:IF A=6 THEN GET #1,A:GOSUB 1680:L=L-1:GOTO 1340
1400 IF A=5 THEN GET #1,B:GET #1,A:L=L-2:GOSUB 1680:A=B:GOSUB 1680:GOTO 1340
1410 IF A=59 THEN FOR B=1 TO L:GET #1,A:PUT #2,A:NEXT B:? #2:GOTO 1220
1420 IF A=10 THEN GET #1,A:PUT #2,A:L=L-1
1430 GOTO 1340
1440 A=PEEK(195):IF A=136 THEN 1070
1450 ? "$)ERROR #";A;" AT LINE ";PEEK(186)+PEEK(187)*256:STOP
1460 REM
1470 REM SET-UP TOKEN TABLES
1480 REM
1490 ? :? " MAC/65 TOKEN CONVERTER"
1500 ? :? "Initializing arrays, ";
1510 ? "please wait...":C=1
1520 READ TOKEN,A$:IF TOKEN<>-1 THEN GOSUB 1600:GOTO 1520
1530 TOKEN=185:A$=",X":GOSUB 1600
1540 TOKEN=184:A$=",Y":GOSUB 1600
1550 TOKEN=7:A$=" ":GOSUB 1600
1560 TOKEN=189:A$=",":GOSUB 1600
1570 TOKEN=193:A$=CHR$(34):GOSUB 1600
1580 TOKEN=182:A$=",X)":GOSUB 1600
1590 TOKEN=183:A$="),Y"
1600 TS(TOKEN)=C:TOKEN$(C)=A$
1610 TE(TOKEN)=LEN(TOKEN$)
1620 C=LEN(TOKEN$)+1:RETURN
1630 REM
1640 REM HEX CONVERSION
1650 REM
1660 FOR A=0 TO 15:READ A$
1670 HEX(A)=ASC(A$):NEXT A:RETURN
1680 C=INT(A/16):B=A-C*16
1690 PUT #2,HEX(C):PUT #2,HEX(B)
1700 RETURN
1710 REM
1720 REM READ DISK DIRECTORY
1730 REM
1740 OPEN #3,6,0,"D:*.*":TRAP 1755
1750 INPUT #3,A$:? A$:GOTO 1750
1755 CLOSE #3:RETURN
1760 REM
1770 REM TOKEN TABLE
1780 REM
1790 DATA 79,ADC,77,AND,84,ASL,68,BCC
1800 DATA 69,BCS,70,BEQ,71,BMI,72,BNE
1810 DATA 73,BPL,74,BVC,75,BVS,42,BIT
1820 DATA 43,BRK,44,CLC,45,CLD,46,CLI
1830 DATA 47,CLV,82,CMP,40,CPX,41,CPY
1840 DATA 34,DEC,48,DEX,49,DEY,78,EOR
1850 DATA 35,INC,50,INX,51,INY,33,JMP
1860 DATA 32,JSR,81,LDA,36,LDX,37,LDY
1870 DATA 86,LSR,52,NOP,76,ORA,53,PHA
1880 DATA 54,PHP,55,PLA,56,PLP,85,ROL
1890 DATA 87,ROR,83,SBC,59,SEC,60,SED
1900 DATA 61,SEI,80,STA,38,STX,39,STY
1910 DATA 62,TAX,63,TAY,64,TSX,65,TXA
1920 DATA 66,TXS,67,TYA,57,RTI,58,RTS
1930 DATA 21,BRA,90,DEA,91,INA,92,PHX
1940 DATA 93,PHY,94,PLX,95,PLY,89,STZ
1950 DATA 22,TRB,23,TSB,29,*=
1960 DATA 14,.END,26,;,19,.ORG,30,=
1970 DATA 20,.EQU,11,.BYTE,12,.SBYTE
1980 DATA 25,.CBYTE,13,.DBYTE,9,.WORD
1990 DATA 18,.DS,2,.ELSE,3,.ENDIF
2000 DATA 10,.ERROR,24,.FLOAT
2010 DATA 1,.IF,17,.INCLUDE,27,.LOCAL
2020 DATA 15,.OPT,8,.PAGE,28,.SET
2030 DATA 0,ERROR - ,4,.MACRO,5,.ENDM
2040 DATA 6,.TITLE,31,.=,16,.TAB
2050 DATA 190,#,187, ,134,$,133,$
2060 DATA 180, <,181, >,138,',159,[
2070 DATA 160,],146,+,149,/,148,*
2080 DATA 167,\,150,&,164,!,165,^
2090 DATA 152,=,156,>,157,<,158,-
2100 DATA 147,-,155,<>,154,>=,153,<=
2110 DATA 179, .OR ,197,NO ,201
2120 DATA LIST,178, .AND ,199
2130 DATA ERR,177, .NOT ,200
2140 DATA EJECT,176, .DEF ,198
2150 DATA OBJ,175, .REF ,203,MLIST
2160 DATA 204,CLIST,205,NUM,202,XREF
2170 DATA 192,(,186,),139,%$,141,*
2180 DATA 191,A,140,%,-1,XXX
2190 DATA 0,1,2,3,4,5,6,7,8,9
2200 DATA A,B,C,D,E,F
2210 END
