I always wanted to put an Easter Egg in The Last Word, but it wasn't until last night that I discovered I'd put one in by accident. :)
When deleting files on the disk menu - either individually or as tagged groups - answering "No" to the "Delete file? (Y/N)" prompt did not cancel file deletion. I discovered this to my cost when accidentally hitting CTRL+D in the disk menu. Pressing Escape still worked, however.
I've prepared a critical fix in the form of release 3.21a. While I was about it, I fixed a bug in the display routine, and implemented support for custom RAM banking tables (useful if you want to specify exactly which extended banks are used). You can read about the changes in LW321A.TXT on the distribution ATRs.
Download and info:
http://www.atari8.co.uk/lastword/
