Kiedys było info o proggu wspaierającego akcje POLAND! Dziś programik dla namiętnych smokersów.Czego to znudzony programista nie potrafi wymyśleć...A może zna ktoś jeszcze bardziej "durny" program?
http://rapidshare.de/files/1028480/Smok … c.rar.html
pass do rara: forum
"Smoker's Calc v1.0 makes calculations which make you think!
Give a few basic details of your smoking habits,
and Smoker'sCalc will calculate:
change in your estimated life span caused by smoking (or by qutting),
amount of money you've lost on cigarettes (or you've saved by quitting),
number of cigarettes you've smoked so far (or you've not smoked since you quit),
amount of time you've spent on smoking (or you've saved by quitting).
The program isn't disturbing and doesn't make you think about smoking.
You can add, modify and delete smokers' profiles with just one click
The results are updated every second - every second matters! :-)
You can easily copy your results to other applications (windows).
Smoker's Calc takes almost no disk, memory, and CPU resources"  ;)  :P
gep/lamers^dial
Gep chyba ci się nudzi...
8)
