For anyone who is building the firmware:
Can you:
(1) make sure you've upgraded to latest ESP-IDF
(2) make sure you've fixed dirent.h as here: https://gist.github.com/tschak909/1ad20 … fde9dac2c3
(3) delete your copy of the sdkdefaults.fujinet-v1
(4) pull the latest fujinet-platformio
(5) clean
(6) build
and make sure that the fujinet completely initializes?
I had to make a change to sdkdefaults to tweak static memory allocation parameters, with the latest ESP-IDF framework, and would like a few more pairs of eyes to see if things are still ok after the latest change.
https://github.com/FujiNetWIFI/fujinet- … 595de011a1
