Using Candle's suggested signal locations and mounting the board in the sensible place (i.e. directly above the OS ROM socket) ensures that wires are as short as they can possibly be on the XL. Attaching wires direct to IC legs may work in the majority of situations, but clearly it didn't in this case (which should on its own give pause to the distributor), and when the CPU is socketed anyway (as it commonly is on an XL), wires soldered to the legs looks particularly nasty. :)
