Problem objawia się od 43 wpisu, nie da się wpisać nazwy partycji - na dole ekranu wyskakują "krzaki". Ktoś z Was też tak ma?
atari.area forum » Software, Gry - 8bit » FDISK 4.67 problem z nazwami partycji
Likely some buffer overflow issue: I will look into it. ;)
Please test the attached version and let me know if the issue is resolved. It wasn't until now that I realised that the bug people had been reporting only manifested itself in 80 column mode. ;) With that information in hand, repairs were easy. Editing of partition names at 40 columns in "Name view" was also broken and has been fixed.
@Pin: It's mean that your partition has been encrypted by some Ransomware ;)
Good point. If only I could add a link to the donate button in the fixed version.
Thanks for confirming. I have replaced 4.67 with 4.68 on the repository accessible by DLT, so it should show up on the next SDX ROM images.
Wygenerowano w 0.015 sekund, wykonano 56 zapytań
