Please find a new beta main BIOS and PBI BIOS for the Ultimate 1MB:
http://atariage.com/forums/topic/240034 … incognito/
Incognito to follow shortly. A few features are incomplete but most things are 100 per cent working.
Zmarł mOdmate Zmarł mOdmate
atari.area forum » Fabryka - 8bit » New Ultimate 1MB BIOS
As I said on your Facebook page, I'm going to test it soon, but now I need to get my SIDE back.
I expect some functionality improvements over a Candle's BIOS :)
Also, what is a software license of that BIOS?
Good question. I will let you know when I find out whether the firmware will end up pre-installed on a commercially marketed product. ;)
I don't mean copyrights, but more like license of code, take a look at this link which shows you an available options, if you don't want to be that 'evil guy' :P
OSS virus spoils another generation of communists :)
W załączniku mój setup Ultimate 1MB z BIOS 2.4 i PBI BIOS 1.3 od Flashjazzcata. Sprawdzony na sprzęcie (działa). Zgrany do pliku programatorem. W środku Q-Meg+ 4.04, XL OS 1.3, XL OS 1.3 z patchem Hiasa, OS B w wersji PAL, Atari BASIC C, a w pozostałych slotach BASIC-a siedzą gry Alien Ambush, Galaxian i Gridrunner :)
Incognito BIOS is new available in the same thread, or here:
Ultimate update, including new loader:
http://atariage.com/forums/topic/240034 … try3389841
Incognito versions to follow.
Incognito build:
I am blind. If there is an old bios, loader and pbi to download somewhere? I need those with old graphics layout.
All must be able to be updated with uFlash.
Na prośbę Skrzypa przygotowałem gotowy obraz ROM-u z najnowszym BIOS-em, PBI, SIDE Loaderem i SDX: http://ftp.pigwa.net/stuff/projects/Ult … M%20images. Nagrałem też poglądowe wideo z flashowania starej Candle'owej wersji. :) Spis tego, co w środku, jest w katalogu. ATR z osobnymi modułami przygotowali Draco i Skrzyp.
stRing: oba oryginalne obrazy możesz znaleźć tutaj: http://ftp.pigwa.net/stuff/projects/Ult … /original/
Może ktoś napisać jak w najnowszym firmware włączać STEREO, tak jak to się odbywa w zestawie Ultimate + Stereo + Uswitch ?
W menu Ultimate jest opcja Stereo przecież teraz.
Muszę Wam zrobić ten poradnik wreszcie, boście chyba wszyscy ślepi są, co chwilę ktoś ma z czymś problem.
Możesz, nie musisz :-)
U mnie w bios 0.47 >System Information opcja Stereo tylko pokazuje informację, sądzę, że zaplanowane przełączniki będą w Device Control, ale u mnie nic się nie zmienia, wspomniana opcja stereo jest zaciemniona.
EDIT: wgrałem ponownie bios - opcja stereo da się zmieniać :-) i działa.
Wersja 0.45 nie działała mi z SIO2BT, a dokładniej - nie resetowało "na zimno" z klawiatury SHIFT+RESET. Musiałem powrócić do wersji 0.24. Czy było coś z tym robione przy wyższych wersjach?
@voy - dzięki za namiary.
No clue what could be wrong with SIO2BT: check high-speed SIO settings, I guess. Shift+Reset problem is a known bug, since the function clashes with partition table re-read (also on Shift+Reset). Thanks for reminder: need to fix that.
IMPORTANT UPDATE for FATFS.SYS users… And likely everyone else, also fixes minor glitches in FAT driver using SIDE Loader, even if this loader does access disk directly.
PBI BIOS was updated to version 1.57, fixes FAT16 partitions bigger than 32MB under SpartaDOS X
Voy's images on Pigwa are always updated, so you just need to re-download them. When you're using FJC's Ultimate "toolset" you don't need to flash AIO image each time, so use "separated files" version and flash only ULPBI157.ROM
If you're interested, FJC might publish details about that bug, because I'm not very knowledgeable in SDX drivers.
Anyway, if you found any bug in FJC's works, don't hestiate to report that! Even when I do intensive stress tests against every software done by FJC, Draco and so on, not everything can be detected that way, so other users' help are very appreciated :)
Z tymi numerami też ciągle jakieś zmiany wcześniej był Bios PBI 1.5.2, teraz jest Ultimate PBI 1.55, co będzie jutro ? :-)
Durnoty pan gadasz, była wersja 1.52 ewentualnie.
To że FJC nie prowadzi changeloga na bieżąco to inna sprawa…
FJC nie odświeża plików na stronie na bieżąco, tylko wrzuca nowe wersje w wątku na Atari Age; tutaj natomiast, w poście nr 18, pod linkiem na Pigwie są najnowsze możliwe wersje modułów wraz z rozpiską składowych obrazu All-in-One. Bonusowo świeża wersja Altirra OS z najnowszej bety emulatora. :)
Info o nowych wersjach modułów i o odświeżanej paczce będzie umieszczane w niniejszym wątku.
Lista składników obrazu 'All-in-One' dla Ultimate 1MB:
- SpartaDOS X v4.47 (7-02-2016)
- SIDE Loader v0.40
- BIOS v0.51
- PBI BIOS v1.59
- XL OS BB000001 rev. 3 (1.3)
- Altirra OS v2.80-test19
- Atari OS B (PAL)
- Q-Meg+OS v4.04
- Atari BASIC C
- Altirra BASIC v1.50
- Galaxian (cartridge version)
- Frogger (cartridge version)
- Missile Command (XEGS slot #1)
Changelog:
BIOS
v.0.51
* Fixed: Inadvertent banking in of SIDE external 16KB ROM on reset (real hardware only)
PBI BIOS
v.1.59
* Fixed: Inadvertent banking in of SIDE external 16KB ROM when ATR swap button pressed
Fajnie by było jakby w tym ATR pojedynczymi plikami był też uflash. Ale na razie mam inny problem po flashowaniu, nie mogę wyjść z SETUPu.
Jest, tyle że pod nazwą AUTORUN.SYS. :)
Każdy pełny obraz wsadu sprawdzam po nagraniu na ATR-a, flashując nim Ultimate'a. U mnie działa. :)
Ale ja nie wrzucilem calego obrazu tylko pojedyncze pliki.
Nic, na razie komp martwy. Flash do zamowienia bo tego Amic programator nie łyka.
Wygenerowano w 0.028 sekund, wykonano 56 zapytań
