Z drugiego stycznia -
http://files.dhs.nu/files_coding/ttruecol.zip
Ray / .tSCc. back with Atari TT C2P-code
After six years of vacation, Ray of .tSCc. is back.
Snippet from the sourcecode comments:
"The idea is quite simple, each pixel is split into a red and a green+blue scanline which are interlaced to comprise a 12 bit rgb scanline. Actually, we sacrifice 16*16 of the 4096 possible colors in order to map the red component into colors 0..15 without visual quality loss, however.
As a demonstration I am converting a 320x480 24 bit rgb picture which is quantized to 12 bit rgb and dithered, additionally."
