Hello  guys,
could you help me please with Atari 800 load "game"?
I'm hunting geocaches and I found one mystery cache in Prague (http://www.geocaching.com/geocache/GC43 … o-ataristy)  (treasure of atarist).
There is load game sound in wav format and it should show the GPS coordintates for this geocache.
Wav file: http://www.archaebacteria.net/atari/atari.wav
There is also some note (http://www.archaebacteria.net/atari/poznamky.jpg):
ATARI 800
- 3 FRAMES
- IR 6 35 A 9255 (or A G25s …not sure)
- stretched tape
Could you help me please how to decode this wav file???
Thank you very much,
Pavel
pavel.halsbach@gmail.com
1st: please do not post twice.
2nd: you need Atari XL/XE emulator. There are few, you could try Altira: http://www.virtualdub.org/altirra.html
3rd: load wav into the emulator and run it
Hi Adam,
thanks for your answer.
I tried severla emulators, but Altira is the first which can load wave.
Unforunately I got error message:
"Cannot read 1004 bytes at location 0062f3fe from atari.wav"
I think it is related to the note: "stretched tape"
Do know you how to solve this problem?
Thank you,
Pavel
Ask on AtariAge in Altirra topic.
http://www.atariage.com/forums/forum/12 … computers/
It really appear to be atari standard tape records in the wave file, but they are interleaved with blocks of random noise that prevent them from being correctly loaded.
