Dość stary hack chyba, ale widzę, że jakoś niedawno pojawił się na DHS, więc może jednak ktoś byłby zainteresowany.
http://dhs.nu/g/files_screenshots/protracker_t.png
DOWNLOAD:
http://files.dhs.nu/files_msx/pt_f40.zip
"Falcon-fixed version (VGA/RGB, 030/040) by Falcon commando"
Ficzersy:
FALCON COMMANDO is proud to bring you
    the Falcon-fixed version of the
PROTRACKER STE. This is the 3rd release
of the fixed tracker, again improved to
   work perfectly on FALCON 030/040.
Some new features:
- Switches back to all resolutions
   correctly.
- You can adjust the screen by click-
   ing on the former NOP-buttons.
   (Warning! Different values for RGB
    and VGA needed! Maybe we'll fix it
    on demand...)
- You can adjust left and right volume
   with the sliders.
- Screenadjustment and volume-settings
   will be saved in setup.
- You can load packed modules.
   Supported packers:
   ICE 2.4, ATOMIC 3.5, POWER PACKER
   (ICE!, ATM3, PP20)
- Fixed to work properly with 68040
   CPUs.
- Resetproof on 68030 AND 68040!!!
   (You may even quit the tracker after
    reset and it's all ok!)
- Playing frequency is now correctly
   printed on screen
- New colours in PT_FAL.INF by DOMM/AM!
Disadvantages:
- Does no longer work on STE
- Does only support 4 voices
- Bugs on some VGA-screens, but's not
   our fault!  Buy another monitor, be-
   cause I am sure that the screen will
   bug in other programmes, too!
- Don't load a new mod while playing,
   if you have started the PRG from a
   very high res (800x608x256...)!
Conclusion:
If there is public demand, we will keep
on ameliorating the PROTRACKER.
If there's no public demand, this will
be the final version of the fixed PRO-
TRACKER for FALCON.
(Consider buying DIGITAL TRACKER from
FRONTIER SOFTWARE or MEGATRACKER from
MCS or whatever...)
Yerzu, ten Hack jest na stronie DHSów od lat.
3 Ostatnio edytowany przez YERZMYEY/HOOY-PROGRAM (2013-01-28 15:47:07)
Dziwne, bo bym na 100% miał.
Ale pewnie masz racje.
Może info przyda się przynajmniej do wzmożenia zainteresowania muzykowaniem na F030.
Bo to w sumie program standardowy, bez francuskich cudów, które wymiatają, ale mogą niektórych zniechęcać swoją dziwnością.
Zupełnie, jak Citroen.
Kiedyś mi się wydawało, że to jest fajne, ale teraz zastanawia mnie jaki jest naprawdę cel "resetoodporności" ?
No właśnie.
Albo ukrywanie "FineTune sample" pod..... "Volume". ;)
Aaaale. Nie moge narzekać, używaaaało się. ;) Album na nim nagraliśmy (w wersji na AY).
Jak wróci mój Falcon, to sobie przetestuję. ;)
Tylko coś się AS nie odzywa w kwestii zwrotu (hahahaha).
6 Ostatnio edytowany przez AS... (2013-01-28 19:02:44)
Twojego Falcona dawno temu jury sprzedał na ebayu a nieodzywam się bo kasę z jurym przepuściłem... :)
Czytałeś maila z ubiegłego tygodnia :P
7 Ostatnio edytowany przez YERZMYEY/HOOY-PROGRAM (2013-01-29 11:09:19)
AS: już czytałem, wielkie dzięki. ;)
Czekam więc na finalne info.
Nawracając do tematu, nie chce mi się już zakładać osobnego wątku, więc wrzucam tutaj (chociaż nakłanianie do używania 16/32bit do muzyki przypomina tu wołanie na puszczy - do sr.ającego kota ;) ),
zgodnie z sugestią 505, zrobiłem wersję twardodyskową DigiComposera (ST/STe).
Jak działa tak działa (no i zrobiłem syfa niewielkiego na grafice), ale nareszcie można używać z HDD, jakby ktoś chciał, a nie tylko z dyskietkami.
DOWNLOAD: http://yerzmyey.republika.pl/digicomp_hdd.rar
http://dhs.nu/g/files_screenshots/digicomposer.png
Hmmmm ???????
tP
Czekałem, czy coś powiesz. ;)  ;)  ;)  ;)  ;)  ;)
10 Ostatnio edytowany przez YERZMYEY/HOOY-PROGRAM (2013-01-29 11:12:40)
Update: http://yerzmyey.republika.pl/digicomp_hdd.rar
Depack all files into
C:/DIGICOMP
This will be Your work-catalogue.
