Official:
http://www.raspberrypi.org/phpBB3/viewt … mp;t=17747
7x130XE + 3xAtari Falcon030 + 1xTT03 + 2xST-ATX
atari.area forum » Emulacja - 16/32bit » STARos: Boot to TOS+GEM on Raspberry Pi
Official:
there is a port of Hatari for RaspberyPi
Link??? It is bootable (or Raspbian, Fedora, Debian)???
Thanks so I will run it on RiscOS? Nice. I will try it!!!
there you can find Aranym and Hatari por Raspberry: http://ragnar76.taurus.uberspace.de/raspberry-pi/
cool!!! thats the solution... can you fix link?
doesnt work
"Incorrect format for file ./languages/sk.txt on line 1.
Format is "variable name[tab]value"
Actually the link works. But in case it may be "sometimes working" I've attached the files below.
First one:
And the second one as well.
Enjoy! :)
Thank you Miker! I will buy you Zlaty Bazant beer on Forever Party!
Miker I can not unzip xz with 7zip... "File is broken."
Hatari works fine.
unfortunately no, that's not my site :)
I've extracted with no problem with 7zip 9.20. Maybe you should try upgrade? Or if problem still remains, try first to save xz file somewhere in normal location, than open - Windows sometimes faces problem when opening directly files downloaded from net - I mean from temporary folder. Especially if they contain special characters (we have + here), or maybe even try to download, rename and then open.
Wygenerowano w 0.017 sekund, wykonano 56 zapytań
