A slideshow from my new computer, the Atari 65XE :
http://www.players078.blogspot.com.br/2 … rante.html
Thank you !
Awesome :-) Looks the same as our ones :-)
Genuineness confirmed :)
Guys,
I need a high-resolution picture from the motherboard, the other owner of this computer messed up with the output video trying to do the "ultra-video" mode, so I need to fix changing to original components again.
Thanks !
Or somebody knows how to extract the video signals from GTIA chip and made a output adaptor ?
Why do you want to go back to original circuit? It was not properly developed. And if someone did that rework, RF modulator should be missed. Therefore you need to obtain it probably.
Jurek, a jak tam u ciebie z czasem na upublicznienie Twojego pacza ultra? Czy może gdzieś jest a przegapiłem?
