does any one know what address i can call in the OS to do
1) Reset VBI
2) Reset DLI
or reset any other interrupts without going throug the warmstart routine ($E477)
Ice-T 2.8.2 Nowa wersja Ice-T dla 8-bitowego Atari już dostępna - poprawki i nowe funkcje
Galactic Panic - nowa przygodówka na ST Darmowa gra point and click na Atari ST - ponad 100 ekranów przygody.
Nowa wersja ARIFE Tool od PVBest73 Uaktualniono uniwersalne narzędzie do analizy obrazów ROM i dysków Atari
Echa Sommarhack 2025 Podczas szwedzkiego party Sommarhack zaprezentowano kilkadziesiąt produkcji,
MadPascal 1.7.3 już dostępny Nowa wersja kompilatora MadPascal przynosi poprawki i optymalizacje
atari.area forum » Software, Gry - 8bit » OS Calls routines
1) Reset VBI
2) Reset DLI
you mean deactivate?
I'm afraid you have to save old values of vectors of page 2 somewhere in memory and restore these manualy later.
yes i mean diactivate.
lda $10 ; save irqens
sta irqen.sav
lda #$00
sta $d40e ; disable NMI
sta $10 ; disable IRQ
sta $d20e
You enable inerrupts this way:
jsr $e46b ; enable NMI (VBL only)
lda irqen.sav ; enable IRQ
sta $10
sta $s20e
what is irqen.sav?, what address is it?
i did find out that to disable vbi calls i need to set the vbi call routine to the original
LDY #<$E462
LDX #>$E462
LDA #$07
JSR $E45C
This is your own label and its address may be everywhere.
To disable VBL you don't need to set its address. Only when you've changed it and want to restore the original. This one you shown is the second phase of VBI. If you want to set the first one you have to load $06 to accumulator.
Wygenerowano w 0.018 sekund, wykonano 47 zapytań
